http://jonmilledgeengineering.com/
nice
I hope one day I get my hands on one of his cams.
Rainman
has anyone proven this?
S3-14 Hydraulic
S3-14 944 2V Best power band 3600-6500 rpm. 900 rpm idle. .474 cam lift intake and exhaust. Stock base circles. Can use stock valve springs or preferably 944 Turbo valve springs for best results. 12-18 bhp over stock camshaft with stock exhaust. Needs stock fuel system pressure with Motronic ECU at click 1. Greater benefits from after market engine management or re-mapped Motronic. Tested against all comparable competitors camshafts and proven better. Can be used for Turbo also. Can meet CA smog tests as either NA or Turbo.
He has an engine dyno and, if you've ever run with one of his cars on the track, you will find he doesn't make stuff up.
If it's the cam I think it is, shouldn't have problem smogging in CA. Of course, depends upon how clean the car was before the swap.
Check with a certain SoCal tuner/engine-builder who is familiar with Milledge cams. The guy that likes to use EFI systems from and builds race engines for guys from the southern hemisphere...
