16v lobe centrelines
They are in the Tech Spec Book (small one), but you have to do the math since they only provide opening and closing points at 1mm lift.
944S
Intake is 112 deg. AT
Exhaust is 110 deg. BT
944S
Thank you M.M. I was hoping you would chime in.
I belive I have this page in a pdf copy of the manual. Shows the cam Part numbers for both 2.5 and 3.0 litre and the opening and closing for each. 2.5 reads 4atdc, 36 abdc for the intake. I did the math and got those same numbers then set my timing..
What got me asking was reading the pages for setting the timing with a pair of dial indicators. It specifies 1.4mm lift @ tdc. That doesnt seem right if it has 1mm lift @ 4atdc .....Am I missing something?Or has something been lost in translation.
Oh, and if this is true, the 944S Intake Centerline would be 108 degrees ATDC.
