Help with low boost
8th Gear
Help with low boost
(Apologies for posting twice: I had this under the wrong thread)
Looking for suggestions before we pull the turbo. The car is only making .3-.4 bar even with the wastegate disabled (which should take all the electronic stuff out of the equation). The shop pressure-tested the hoses, etc. inspected the testpipe and down pipe for any blockage, and has run out of ideas other than a bad turbo or possibly collapsed cross-over pipe in some place they couldn't see. Turbo doesn't have any play in it or friction, but apparently that doesn't always mean anything.
Any of you wrenchheads have ideas?
How was the wastegate "disabled"? If it's still in place but with the air signal line is clamped off, that doesn't eliminate wastegate issues like the wastegate valve being stuck open.
Find out. I don't know how you'd "wedge" it shut without pulling the exhaust off (which maybe they did).
Any other details on your car? is it stock? Did the problem just suddenly show up?
Welcome to Rennlist,
Rob
