About six inches, - there's some Heater Duct back there to contend with if the unit is longer on the top side, bottom DIN room is longer.
Yes, Bluetooth, iPod, DVD/CD, AM/FM, 6.9" Tilt Screen - touch sensitive, Menu and adjustment screens, and a GPS that talks German to me. GPS can be removed for use in other vehicles also, but without the bitchin! NLA Alpine.
Depth is the big problem with the double din. If you pull the cubby out, you can see where the angle of the bottom changes. That point is where the double DIN will hit the tunnel. I had to dig out all the foam and sound deadening to fit mine. I also modded the bracket that sits in there too.
I believe mine is about 6.8 deep. But when I measured the depth I think it will work with a little bit of modification if any at all. I am really excited to get mine in cause they do fit that center console so well. and BTW that unit with the megasquirt....holy cow thats awesome
Well here it is. I have to figure something out with the faceplate. Not sure what I am going to do but I will figure something out....hopefully. I currently have that tubing there just to hold the unit up instead of sitting on the center console mounting screws. Not the clean look I want but if anyone has ideas what to make the faceplate out of or a universal one they have used let me know!
My Wheel is a Momo 'Jet Fighter' ... I wanted a touch of Carbon Fiber in my Life, but that's all the Thumb Pads provide. Horn is still the Hub. 10 mm smaller diameter, and surprise surprise, a Guy can now see the Gauges, Switches and Stalks, ... pretty much forgot I had CC.
