Starter motor wiring.
Professional Hoon
Because my battery is in the boot i'm a little confused here.
Does the starter wire (+ve) connect straight to the main cable going from the battery to the alternator?
I believe so yes...since there needs to be a big cable between the battery and starter anyway, it makes sense for the alternator to make use of that, rather having a separate run the full length from alternator to battery.
