Weltmeister sway bars?
I finally got both of my sway bars on and I need a little help getting them adjusted. I put them on with the car on ramps to try not to get any preload on them. I did the front one like they said and started about 2" in with the adjusting slider. The car is a lot more responsive now but if I go in a parking lot and turn the steering wheel all the way one way or the other I get some wheel hop kind of like when you drive a truck in 4 wheel drive on a dry pavement. What causes that do I need to shorten the drop links some? I was also wondering if it is normal for them to be a little noisy when going over bumps and going into driveways? I assume that is normal because of the lack of rubber parts there now but I just want to be sure nothing is wrong.
