Quieter Exhaust?
Quieter Exhaust?
Okay, I've zipped up my Nomex so here goes....
I've currently got the 3'" Fabspeed cat bypass exhaust on my car and while it does open up airflow for the turbo and looks great, it's also quite loud and I get the occassional pops from not having a cat. Well, I'm getting tired of being "warned" by the local authorities so I'm looking for something that will quiet things down a little, get rid of the pops (yes I know that means going back to a cat), and basically get me out of trouble with the locals but still give me better performance and flow than the stock exhaust. Any suggestions? Something with a performance cat perhaps?
G'day Dwayne,
Stirring up the local cops huh ? I think you will find that adding a 3" performance cat to your fabspeed will probably solve your problem as it will kill off most of the popping and may be a little quieter as well.
How about just trying to fit on a resonator?
This will cure your problem of noise and possibly absorb the excess fuel/fumes you seem to be igniting.
Don't worry I have the same result with my 3" no cat exhaust, but I don't get hassled by my local cops, YET anyway.
Have fun
Have fun
Dwayne, on the popping sound - for me anyway, purchasing the Lindsey BOV pretty much stopped most of the popping for me.
I have the complete SFR 3" and sometimes the wife complains a little. So my solution was this: I still had the whole factory setup,
so I had a local shop cut the factory muffler off at the back. He then welded on a 4" pc of three inch mild steel, expaned it just slightly, split it
on both sides. So now if I need to quieten the car down I just swap the mufflers out, takes about 10 minutes. BTW, since I have the WBO2,
that swap increases richness about .1-.2 over the entire range of boost from where the car was tuned with the SFR bullet.
