More lag, less boost.? help
Professional Hoon
I would, i probably should. But i would only do it if i get a new wastegate with vband.
As mentioned above; try the Nord-Lock washers, and check the website if you don't think that they'll hold better than the normal spring washers, spring washers loose their strength when they get hot, Nord-Lock's don't have that problem!
Professional Hoon
At the moment i have nylock nuts and 2nd nuts to hold them. I also put gasket glue around it, and it seems as that could have been the issue.
And i have a feeling the fuel is **** too. Will be filling up with 98ron next just to compare.
