Designing a realtime performance monitor for my 951- inputs needed
I am finishing up a basic design of a custom touchscreen LCD display (4.2") to display certain parameters in realtime and also to perfeom some data logging. I am/ will be monitoring turbo boost pressure, exhaust pressure, wideband AFR, knock, fuel pressure, rpm and mph. I am sure I can buy something that will do the same, but I am doing this for fun as much as anything else, I design instrumentation as a profession so why not for my P car? I have a stripchart display, data logging and other display ideas. I have an acceleration display that computes your accelation times from a start and end speed.
so my questions are:
- Are there any other things I should consider monitoring?
- any suggestions for plots like AFR vs boost?
When I am done, i plan on sharing the design on rennlist so others can use it if they want
[IMG]
[/IMG]
[IMG]
![](http://i1210.photobucket.com/albums/cc403/use2windsurf2/32cb1fb63a52ed6f91b59bd950f3a429.jpg)
Great idea!
Knock counts - I think you could display these as both a static value (cumulative) and they could be plotted over time on the boost/AFR screen. The same scale you use for boost could be used for knock counts per cycle.
cool project. Will it have accelerometers so it could do automatic 0-60 times or in my case 0-100KPH ? It's too hard to hit start when you are trying to launch, so an automated movement sensing timer set up would be cool. Will it be metric swappable ie do both mph and KPH ? Would it be possible to display approximate RWHP based on measuring other data ? G force data ?
Sorry but you did ask
cool project. Will it have accelerometers so it could do automatic 0-60 times or in my case 0-100KPH ? It's too hard to hit start when you are trying to launch, so an automated movement sensing timer set up would be cool. Will it be metric swappable ie do both mph and KPH ? Would it be possible to display approximate RWHP based on measuring other data ? G force data ? Sorry but you did ask ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
