m-tune tuner/logger
I expect that it will be supplied with all optional maps populated... the idea is to make the kit even more universal, so if you have a 2.5L and later switch to 3.0L that the Map is already there, no need to for a chip-swap. Same thing if you wanted to try E85 vs race gasoline.
Furthermore, the Maps are now open, so the functionality of my DME Tuner setup is being built-into the new chip, and will come standard (you just need to be able to burn chips or get an emulator to take advantage of the open hardware).
Small Business Partner
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
It is the #1 priority right now, and in the last throws of completion now.
I suggest waiting just a little bit for me to release the new chip first.
Well thanks for the heads up, I was considering getting the tuner/logger combo myself. Sounds like your getting rid of some of that hardware with the update.
I will continue to patiently wait....
The new features sound exciting and may have pushed me over the edge to a purchase. From following prior posts closely, Josh has provided stellar service on getting the MTune installed and running. My question is....if I now must purchase through Lindsey, who will be providing the support? Also, the Lindsey site notes that my 86 24 pin DME will need to be changed to a 28 pin but they make no mention that they offer this service, who will do this?
Don't want to step on any toes, so only if Josh doesn't do this anymore...
I could help out on the conversions. I have 3 decades experience with electronics, have a recent J-STD-001 soldering certification, and have worked on electronics launched off military aircraft. And I've done several of these conversions all ready.
Like I said, I'd be happy to help out but only if appropriate and not stepping on toes.
