early electric sunroof sort of works?
Professional Hoon
I'm having trouble with my sunroof.
Clarks garage is no help
It won't let me remove the sunroof. (ignition on accessories (first turn) )
When the key is on the "on" position the motor moves but won't lift the sunroof up. it will slightly move, but only one arm moves a bit and stops. and on the way down it will go back to where it was.
I dont have the gears in the sliders.. i have the gearbox in the middle. so only one slider sort of works, the other seems stuck.
What do i look at?
What do i look at?
Paul IIRC, I think you need to drop the headliner to access everything. Not a terribly hard job, but no fun either. You could try gaining access to it, then shooting some silicone lube spay into it and working the motor back and forth to see if it loosens up any.
