T04E question and any opinions?
Thoughts or opinions on this for replacing the 26/6? Not water cooled, so it requires rerouting water lines, but is this a decent upgrade or should I look elsewhere?
New T3 / T04E / K26 #6 Hybrid Turbo with:
.57 trim compressor wheel
Stage III turbine wheel
Supports up to 390 HP
Oil/Air Cooled, 360 degree Journal Bearing CHRA.
(Bolts right up to stock 951 exhaust up and down pipes, boot modification needed for 3" inlet)
I have the vitesse maf kit, 55# injectors, 3bar fpr, vitesse chipset, and sfr's 2.5" intercooler pipes waiting patiently at home.
I am hoping to lay some decent HP to the rear wheels @ 18psi, but I still need to decide on the turbo, wg, manual or electronic boost controller, and a decent wide band.
I have a dansk cat-back exhaust already, I don't know if I am ready to pull the complete exhaust and do that upgrade yet.
personally if I was doing a smallish T04, I'd be looking for a 50 trim since it'll make nearly the same power on pump fuel while spooling up faster and having a lower boost threshhold and improved transient response. Also I would not run any T04/T3 with a #6 hotside.
If I am staying stock with the porsche downpipe and the pre-cat exhaust, does having the #6 hotside really hurt the hp at high rpm's due to the backpressure? I would think my stock downpipe and stock pre-cat exhaust is the culprit for power loss at higher rpm's due to not allowing enough air volume to escape fast enough.
I'll check with them to see is they would offer the same specs with a #8 hotside, if so I'll take the bait!
Pictures are always appreciated
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
I can take any picture you want, here is an older one from when it first went together. Deleted any coolant lines not needed and running an n/a coolant tank and a block off plate on the water pump.
N/A coolant reservoir, that saves me over $200 to replace my yellowed turbo one with a new n/a one, sounds good so far.
Did you have to do anything on the metal coolant tube in front of the radiator, or just installed the block off plate and cap the metal line there?
So many questions now.
You setup is pretty much what I would like to see on mine. Any dyno specs? Do you have a build thread on rennlist/pelican I can inform myself with?
We pulled out anything that was no longer in use so all metal coolant lines gone. Think it did a best of 380/430 at 24-25 psi on a dynojet and was still making power. I run it at 17-18psi around town, prob 310-320rwhp. Oh and I think I am 6+ years now on this turbo with no issues (built by Bob @ Turbo-performance).
Thanks again.
