What Gear should I see Max Boost?
#31
Originally posted by sm
Thanks for the replies. The car is quite fast at the low boost I'm seeing right now; 15psi must be almost scary!
What did you do to your car? you put new GURU wastegate or a reliaboost?
#32
Simpson, I'll be impressed if you hook up that socket as a test lamp AND install it in the proper place in the rear taillamp cluster. I'll be happy to follow you around and read the codes.
#33
Update Part II
I drove the car last night with the hose between the Reliaboost and wastegate disconnected. Maybe this didn't do anything, but I wanted to see if the wastegate would hold boost on it's own, and it felt like it did. I saw maybe 9 psi in third gear, which was more than the 7 psi or so that I saw with the hose attached. I am not 100% sure of this, however, as I was careful not to overboost. Did this *test* prove anything?
My CV is disconnected. Will a this setup still allow for overboost protection and drop boost to ~7psi?
How do I test for a pooped wastegate?
And how do you connect a dual port wastegate to a MBC, such as a Reliaboost?
Should I suspect a weak spring in the Reliaboost? It has been adjusted to near max already.
#34
But on a serious note (I was only semi-serious above), I'm thinking about hooking an LED up to the gauge cluster for this purpose (a la Perry).
Does the testing of the codes have to be done after a drive, or can it be done on startup? I didn't see any codes come up when I performed the test right after starting the car.
#36
Originally posted by toddk911
sm, if you disconnect the wastegate and run the car, should see a TON of boost. If not, wastegate is bad.
#37
#38
Drive-by provocation guy
Yes, correct. I was assuming he had checked for leaks. What vac are you reading on boost guage?? And if yo uare going by stock guage, that could be way off.
#39
I get about 20 whatever the units is (inches?) at idle. Is that about right?
And I did snoop around the engine bay looking for loose hoses, but didn't see any. I'll look again...
Still trying to get answers for these q's:
Thanks!
Thanks!
#40
I just checked the fault code reader and there are no fault codes. I checked all of the vacuum hoses (rubber and hard plastic), and everything seems fine. Oil still smells like gas and I can't get more than about 7 psi.
Well, I'm going to go change my oil now.
Seems like a new wastegate is in order?
#41
Are you absolutely certain you don't have an intake leak?
#42
Originally posted by Jake951
Do you mean it's bypassed or that you just pulled the hose going to the WG and left that hose disconnected?
Probably the surest way is to remove it and test it outside the car with a pressure source...not the easiest way, though. If you disconnect the line from the CV to the WG (pull it at the CV) as a test, then you should be able to develop maximum boost if everything else is OK.[/B]
Are you absolutely certain you don't have an intake leak? [/B]
I'm not absolutely certain that there aren't leaks, but I have checked pretty much everything.
I'm now going to pull my injectors to check for leaks (gas smell in oil - still).
Thanks for the help
#43
I get about 18 in of HG at idle when the car is warmed up. However, the needle on the aftermarket gauge does move a tad bit when the idle speed moves. Idle is about 900 rpm's, but does sometimes drop to 700 rpm's.
Also, have you tested your BOV?
#45
I'm going to get one of those vacuum tester hand pump things.
