Garage Sale, help me make room
Folks, help me make room in my garage. None of this stuff is doing me any good sitting on my shelves and its time for a winter clean out. I can't even remember how I got a hold of half this stuff, so just make me an offer and get it out.
Stock intercooler, good condition and no dings-- 100
Good, clean 3 piece OPRV -- 85
N/A oil filter housing/oil cooler -- 50
Working hatch lift motor-- 30
working rear wiper motor-- 75
N/A AOS/oil filler -- 25
Stock intercooler hard pipes, small dings -- 35
Early alternator--- 30
Pair of stock N/A front springs -- 15
2 Turbo coolant temp sensor/coolant inlet Y pipes, 1 has banjo bolt-- 30 each
Coolant crossover pipe for turbo car-- 50
944 turbo coolant expansion tank-- 75
2 good used factory fuel pressure dampers -- 25 each
2 pairs of stock spring top hats--10 each
set of late offset power inner tie rods, never installed and still in plastic --60
set of late offset power inner tie rods, installed and used for about 1 week on the street before I decided I wanted to convert to early offset --45
Rebuilt N/A clutch fork with new bearing-- 90
working ignition coil--30
headlight motor--35
headlight bar with linkages--25
Complete pair of rear seat belts--100
Cam tower with early N/A cam, no lifters-- 100
4 late car cooling fan relays, 70 ea
Brand new front cam cover with new gasket, never installed--40
4 fuse tester relays---10 each
distributor rotor--10
OEM spark plug wire set-- 30
Crank/alternator pulley--15
2 power steering pulleys-- 15 each
power steering cooler-- 25
power steering tank-- 15
LT1 MAF-- 15
stock N/A throttle cam-- 5
stock wastegate w/ shim (core only)-- 35
A/C compressor, unsure if it works but good core-- 35
pair of motor uprights w/1 good motor mount-- 25
A/C adjuster rod-- 15
Power steering adjuster rod-- 15
set of 4 cast N/A rods and pistons-- 100
N/A flywheel --15
engine alternator/AC mounting bracket-- 20
pair of late tan leather seats, ripped, driver side is power-- 150
late offset conversion stuff, caster blocks, sway links, ect -- ask about them
headlight motor--35
LT1 MAF-- 15
N/A flywheel --15
