Car starting issue..
Okay, so my problems are as follows:
Car will not start, even when hot, sometimes. I can turn the car on and drive to Vons, but when I attempt to turn it on again, it won't start. This happens at about a 6-1 ration, it turns on 6 times, as appoused to the 1 time it will not. I did buy a new DME relay, and replaced it, still nothing.
The battery is 6 months old, and can hold a charge. When I try to turn it on, all it does is crank and crank. If i was to give the car a couple hours to sit, it would turn on then. Anybody got any ideas? Perhaps the alarm? Please explain in detail...
Thanks.
Thanks.
You might have a grounding issue. When the car gets hot, the ground wires build resisstance and once they cool down, they work correctly. I would look into the ground cable going from your battery terminal to the engine block.
Welcome to the world of reference sensors. Seems like it has plagued a few cars recently including mine. They are 2 sensors, both connected to the engine harness right between the engine firewall and the intake manifold's back. You can try wiggling them and see if that works. Either your sensors could be gapped incorrectly or may have gone bad.
Best thing is to see if the tach moves when you crank, if it does, it getting signal from the sensor.
Okay, my tach only rises half a millimeter (what does your tach rise to when you attempt to turn it on, i never paid attention to this, mine doesn't even hit the first notch when its been cranking for at least 10 seconds.) when i attempt turning it on. Please guide me in more detail as to what the reference sensor looks like, and where it is planted. Thank you.
Thanks.
Cyrus951 - in response to your desparate plea - the reference sensor plugs are usually the culprit. They are mounted on a metal bracket, one above the other, at the center rear of the engine. Next time it refuses to start, grab both ends of each wiring plug and vigorously wiggle them and then start it. You can try cleaning the connections but I had no success doing that and ended up soldering the wires together.
Just an added note: if you do change the sensors, you are still plugging them into the old plug on the wiring harness, and in my experience, it is the plugs that are defective, not the sensor itself.
