Spark Plugs
Hi All,
Just got in my COP's, the 0 986 221 050. They look really nice but are actually a bit too short. So i was wondering if anyone knows of the existance of "Longer" sparkplugs. And than not the part with the thread on it to get into the engine but the part on top. Mine are 40mm at the moment but should be 45mm and it would even be the best if they were 50-55mm. If this does not exist i'll have to get a M4 thread and get it on the mill to do the rest..
And than also; what are the recommended spark plugs for this engine?
Thanks,
Bas
Thanks,
Bas
Bas,
any chance of some pics ? I've been chasing COP for ages but never knowing what might fit.
Lack of parts here means I can't experiment much.
cheers
Mike
cheers
Mike
This is what I did:
The spark plugs still stay well in the insulated area so there is no risk involved here. Still it would be nice to have it different! (these are 21mm spark plugs)
![](http://www.industrial-sounds.com/944/s2tproject/IMG_6798.JPG)
![](http://www.industrial-sounds.com/944/s2tproject/IMG_6800.JPG)
![](http://www.industrial-sounds.com/944/s2tproject/IMG_6799.JPG)
This is my solution with the COP's. They are from a Audi W12 engine and cost about 33 euro's each.
I could not find the Audi W12 part number from my parts supplier, but I did pull up a couple of Audi models that appear to use a similar coil.
A 2013 Audi RS5 , 4.2L V8 engine uses p/n 07K 905 715F. The Bosch option (cheaper) has the stem insulated by a rubber sleeve, but otherwise looks like what you have. The Genuine VW / Audi option is almost identical.
A 2013 Audi A8 Quattro, 3.0L V6 uses p/n 06E 905 115E. The Bosch again uses the rubber sleeve and looks similar. The Genuine VW / Audi has a red top but appears very similar again.
Have you tried any other Audi model coils? What directed you to specifically use the W12 coils over any of the V6 or V8 options? Do you know if any one coil model is more powerful than the others?
Thanks for the info!
He Vic, I'll try to find some specs for you. Raceboy recommended these coils to me! I'll contact Bosch to get some more specifications on them
Rainman
as far as your reasoning to go to these types of coils, are you expecting to push a ton of boost requiring a better ignition system, or do you need the space on the front of the engine, or eliminating a mechanical failure point (distributor rotor/cap)?
