FS: Parts from '88 951S
Rennlist Lifetime Member
Selling a few spare parts from my '88 951S race car. Prices do not include shipping or PayPal fees. Can arrange pickup or delivery within reasonable distance of Indianapolis, IN.
Note: Everything is from the '88 951S...I'm not an expert on 944/951 variants so I can't provide authoritative advise on fitment for other cars.
An album of pictures of all items can be found at: Car Part Pics. Specific pictures inserted below where possible I I'll add more as time permits.
Please let me know if you have any questions.
All the best,
Rick
Here's a current list of the items...I'll do my best to keep this list current.
Items below Sold
$40.....Sparco Cool Shirt
$10.....Belts (price for both) Belts
$45.....Brake Cooling Back Plates (Barefoot Racing)
$20.....Power Steering Pump
$45.....Rennline Al Pedal Set
$30/Each.....Rotors. OEM Fronts - used for 2 track sessions. Lots of life left. OEM Front 1 OEM Front 2 OEM Fronts Side View
Kill Switch
$20.....Saiko Catch Can (used & a bit scratched up but works perfectly)
$6......H4 130/100 Yellow Headlight Bulbs (priced each)
$50.....Kokeln solid torsion bar mounts
$15.....Brake Pad Backing Plates (Titanium from Racer's Edge)
$20.....Wheel well liners (priced each). I have multiple.
$10.....Window Switches (Pair)
$100..... Airbox (all mounts intact & no cracks)
$50.....Airbox (one mount point on lower right side missing)
$30.....Hood Insulation Pads (from Performance Products. Brand New)
$1.50.....All of the Spark Plugs - all New. BPR7ES. Priced Each.
$50.....Fuse Box
$25.....KLR Box (no chip)
$35.....Fuel Rail #2 Fuel Rail Pic2 Injectors sold separately
$50.....Intercooler Hoses (New Lindsey hoses - still in sealed plastic)
$400....Lindsey 3” Exhaust. Full system...no cat w/ muffler delete pipe temp welded in. Includes 3" Magnaflow muffler
$30.....Instrument Gauge Surround w/ Boost Gauge & Wideband Gauge Ins Surround2
$20.....Rear Tow Hook Bracket
$25.....Fuel Rail #1 Fuel Rail Fuel Rail Pic
$150.....Front Bumper Cover. Color is guards red. Ideal for race car but would need repaint for concours expectations - appears to be amateur paint job previously. Photo1 Photo2 photo3 Photo 5 Photo 6 Photo 7 Photo 8 Photo 9 Photo 10 Photo 11
$20.....Instrument Gauge Surround Inst Surround
$50.....Shock Doctor Helmet Dryer
$135/each.....Rotors. Rear 951S Rotors. Chyro Treated/Slotted. Never been mounted. Rear Rotors
$140.....Rear Axle ( GKN #3000684 New in Box) I have 2...priced Each
$10.....Longacre Helmet Hook fr Roll Bar
$20.....Longacre Water Bottle w/ Roll Bar Attachment
$125/Each.....Rotors. Fronts - Chryo Treated/Slotted. Mounted on to car & moved around lot. No track use so essentially brand new. Front Pair Front Treated 1 Front 2 Front Side View
All the best,
Rick
- $40..... ABS Sensors (price for all 4 pictured)
- $50..... ABS Line Controller ABS
- $25.....ABS Computer ABS
- $50.....AFM
- $9..... Air Filter
- $50.....Aluminum Bumper
- $20.....Alternator
- $10.....Alternator Bracket
- $8.....Alternator Shroud (stock)
- 35 .....Alternator Shroud (for A/C Delete setup)
- $15.....Alternator Cooling Hose
- $150....Arnnworkx Tools - Engine Kit + Bearing Remover
- $25 .....Cam from 21K mile car
- $45..... Crossmember (stock...not modified)
- $10..... Dashboard End Caps
- $100....Fender - Passenger side. Color is guards red. Currently has vinyl wrap applied which can be easily removed. Photo 1 Photo2 Photo3 Photo 4 Photo 5
- $10 Fender Brackets Fender Brackets
- $150.....Headers (Original from Turbo S)
- $40.....Headlight Assembly
- $20.....Headlight covers
- $20.....Headlight Motors (Pair)
- $30.....Headlight Surround Plastic Pieces (price for the lot) HL Pieces
- $45.....Intake
- $40.....Intercooler Duct (Like New) Duct
- $20.....Intercooler Pipes (OEM...price for 3 pipes pictured)
- $10.....Lug Nuts (New). Price for the 7 pictured.
- $250....M030 Spindle - Right ( modified for 19mm pin)
- $15.....Power Steering Reservoir
- $40.....Radiator Fan
- $50.....Rear Seat...lowers & backs
- $25.....Spare Snorkle
- $80....Set Springs (700lb springs are Eibachs and are 8" long. The 600lb springs are Hypercoils and are 7" long. Both were used on my car with Motons)
- $35.....Starter
- $20.....Thermostat (New)
- $25.....Turbo Cooling Pump (9sed)
- $23.....Window Motors (Pair)
- $20.....Windshield fluid washer tank (missing the cap on the bottom of the tank but otherwise very clean)
Items below Sold
Kill Switch
$50.....Fuse Box
PM sent
Do you have this plastic piece?
List updated...items that have been paid for removed from list to eliminate confusion. All items that have been paid for are in process of being prepared for shipment & will ship by Wednesday at the latest via FedEx Ground.
PM sent on the exhaust.
