IN CAR VIDEO (New & improved!)
Impressive would be an understatement.
It's clear even at the first corner on the warm up this car is generating some downforce (erm - alot!) .
Is the noise when you first start the fuel pump?
I can't believe it's generating one ton of downforce at the back. With whatever is in the front, you're surely making more than the car's weight. That said, I don't recommend trying any stunts driving on a ceiling!
Have you considered putting a screen over your front cooler? Out in the open like that seems risky. Obviously a screen would limit flow, but I don't know if you ever get rocks kicked up and whatnot.
Thanks for sharing!
Thanks for sharing!
Very cool video/car, regardless of driver
Unfortunately, the new system prevents edits to old posts so we'd need to call on Shawn to update the list with his special moderator powers...
p.s. is MoTec any cheaper down under? It costs more than most 951's in the states...
I want to put in a diffuser even if only cosmetic as I think visually we need some balance. We have a lot of rear downforce but ultimately would want a working rear diffuser too. We are putting diffusers in the splitter too. Do you have any decent pics of yours?
Cutting into the bumper and rerouting the exhaust should get a little more room
If nothing else iirc the aftermarket FC rx7 ones fit but I question the effectiveness
Unfortunately it's not just a matter of slapping on some aftermarket piece. We have rules to work within which state we can't run a diffuser past the line of the rear axle. We've also got our fuel system in the spare wheel well and even though that's been cut and fabbed to remove about 4" it still impedes the line of a diffuser. We could make something up that could work around these constraints but to do proper custom job won't be cheap. We can run the splitter and diffuser to their axle lines respectively. This means that in between these parts the uncovered underside of the car is exposed creating dirty air. The diffuser 'might' clean some of this up, might not. With the rear wing overpowering the front in terms of downforce I am better off spending money on the front end than the rear...as much as I'd like to complete the overall Aero package.
The car will be resting on the hoist by December George. Pity you won't get to see it run.
Professional Hoon
Love this video. I love sharing footage of your car on fb. It really makes the "JDM" worry that there's older cars better than their vtec burners.
I'm afraid that no one knows how old these cars actually are and and realise it has 8v and a torsion bar in the rear.
Thanks Pauly. When we look at the specs of some other cars and also the amount of boost they're running, it does seem amazing that we can keep up or even beat some of these guys. Have to say that I'm guessing that Paul is a superior steerer to some of our competitors too, which can't be discounted. Having said that, he was driving the Pulse Evo and while that didn't quite reach it's potential, for us to almost win outright on that weekend in our car is pretty incredible. If we can attract some sponsors we might be able to undergo a few more changes that would take the car to the next level.
Thanks Cyril...right back at you!
Professional Hoon
Seeing as though you've got a head gasket issue and running 7psi less boost than desired.
Paul is a very good driver, But that pulse Evo has probably more dollars spent on it than yours.
When you look at the back you can see the tube suspension subframe.
I'm sure when you sort out the HG issue, you & Paul will do very well at 14' WTAC and hopfuly you do pick up a sponsor!
Did a bit of editing with some video I shot while walking around. A pro I'm not, but gives it a bit of an extra dimension.
