Possible silly question re: Robby/IceShark battery cables
So I've got a set of cables from Robby. I got them almost a year ago, just now getting around to installing them.
It includes the "supplemental" 4awg battery to fuse box wire.
Right now, there is this "bundle" of ~5 smaller gauge wires running from the battery to the fuse box. Is this supplemental wire intended to replace those 5 smaller wires, or run in addition to?
My guess/assumption is that it's to replace them, and then I just need to add a sort of distribution block under the fusebox to connect it to the various places on the box itself. But figured I'd check first, since it's just as easy for me to just replace the 5 smaller wires with fresh (but identical) wires... though then I'm not quite sure what to do/how/why to route this supplemental 4awg wire.
I PM'd Robby but he's not here all that often and figure the collective here would probably know the answer.
Jim
Jim
its was pretty easy. the Drilling was the hard part and only because you had to be very very careful.
