is this a original Iceshark battery kit?
Basic Sponsor
I can take a picture of the Ice Shark harness installed. I have two complete sets on both of my cars, both the battery and headlight/driving light harnesses with additional grounding. I don't think anything could be better than these kits,
Possibly on par, but not better.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Yes, that is part of the complete kit, the battery part. Mine has quite a few more pieces, and I still say the one you pictured is on par not necessarily better. Of course either are better than stock.
This thread had a good discussion about the iceshark/battery cables I thought (and my Iceshark cables still look new)...
https://rennlist.com/forums/944-turb...m-memmolo.html
correcto.... Mine actually has more pieces to it. Please check your "kit" its no where near to what you have pictured above. Please look at what i wrote and compare. Let me mentioned this that i failed to mention before. My kit has been installed for over 3 years now and its still looks new. That "kit" you have looks beat up specially with that exposed wire. Also have you ever seen a Ice Shark kit? please check current draw on the cabling.
Basic Sponsor
it's was used for over 4 years on a track car. The cables are thicker and I don't see any exposed wire unless you are wearing microscopes and not glasses. The koawood kit has better cables.
1 Post
I don't see the exposed wires either and the kit looks solid to me. That being said, the kit in my FL is over 10 years old and it looks brand new. The one in my CA car has only been installed for four years so not a good comparison, but of course it looks new as well. I am sure both are a fine upgrade, especially for what I am sure you are going to get rid of it for. It will be a bargain for some lucky guy.
I dont know if we are seeing the same thing or is it that you are having trouble with your 1" thick glasses but the kit I have shown on the fist post is used and
Look at the ground cable on the lug side. does your kit include an upgraded voltage regulator, 2 layer shielding, additional grounds, supplemental grounds? Lart do have data on both cabling of the kits to prove your point??
Basic Sponsor
While we're on the subject of battery cables, if one were to build their own, and they have a super awesome surplus shop in the area where they can buy almost any kind of cable under the sun, what would be the best choice out of the following three:
Normal Automotive cable
Marine cable
Airframe cable
Their temperature raiting increases with each one, Marine cable is rated at 105C and Airframe at 150C. That said I don't know if the airframe cable is made for living in an engine bay, or how pliable it is. I'm leaning towards the Marine cable.
Here's links to the marine and airframe cable where they list the specs, the automotive cable isn't listed on their website but it's in store.
Marine: http://www.skycraftsurplus.com/1awgb...bythefoot.aspx
Airframe: http://www.skycraftsurplus.com/1awga...wireblack.aspx
I love that store so much. I can literally walk in and leave with everything I could ever need (and usually some stuff that I don't need).
Marine cable
Airframe cable
Basic Sponsor
did you get my pm? obo
