Lindsey vacuum hose kit?
#47
Split down the middle. If I had to do it again, I would buy the SFR hoses with stronger hose wall. I am sure 99% or whatever of their kits are fine. I just dont like the odds when I am that one.
#50
Originally posted by Ben Z.
Jon-
Thanks for the tip for slotting the Bolt hole for the dipstick mounting bolt. I'm pretty sure I spent about as much time on that bolt as on the rest of the procedure! BTW- is it possible/easy to replace the o-ring at the bottom of the dipstick tube w/o removing much stuff? Thanks.
Jon-
Here is anther tip.Do not remove the dipstick from the intake manifold.Just loosen the 10mm bolt and remove the dipstick with the manifold.Works wellI have done it about 100 times!
#51
Originally posted by NZ951
Ahhhh! My dipstick came out the other day when I was trying to bolt it up, I mean the hole assy came out. Now I have an oil leak low in the engine. I though I had put it in back right, nice solid clunk. So I guess the o-ring is not in right? Or there at all... anyone got the part number handy?
I would describe the Lindsey hose failure as usual for me. As it has happened. But I imagine unusual for most people. I think the SFR kit has better quality hose walls... IIRC. Tim, can you advise?
The silicone hose we sell is about twice as thick as the stuff Lindsey sells while maintaining the same ID. It is also quite a bit more expensive. Unfortunately, doing it right doesnt neccessarily mean doing it cheap.We have had too many problems with the thin, soft vacuum hose and splitting/cracking is a normal occurence so we stopped selling it.
#53
Tim, you mean taking the whole dipstick and dipstick holder out? I did that last weekend, no I have an oil leak from low in the engine. Not sure if it is from there yet. I have ordered an new seal.
#55
No its not listed, and many parts which are listed, he no longer sells. It would be great to see all the parts he offers on there!
PS Tim if you have an IC duct for the header panel vent system, I would love one!
