968 piston squirters part # ?
11 years later... still no number.
I have searched online but nothing. Even their page does not exist anymore..
Porsche part # for 968 squirters is 944.101.018.01
Last time I bought them in Dec. 2010 from Sunset, they were $25.90/ 17.88 List / Net. They had to be ordered from Germany. I believe they are $28.75 List now.
The block should be drilled so the squirter points towards the exhaust side of the piston, which varies slightly depending on if it is a 2 or 4 valve application.
For those who may be interested, I have a brand new set of Mahle 104.5mm 2 valve turbo pistons for sale, and I have two S2 blocks available.
John
John
Thanks, just what I needed. I searched trough 968 PET and it does not mention squirters at all..
Chris White has KMR squirters or are these all different?
I will need a set of pistons like yours, but as Ive just bought 2.7 block and 968 crank, cant afford them atm. Have to sell my 101mm turbo mahles first.
Hi, I don't know if this will be of any help to you, but when I built my turbo S2 engine I used an oil jet from a Ford Duratec engine. It is a complete item which has a built in 35 psi spring. I drilled the block through the main bearing journal at a 15 degree angle, you tap the hole and screw them. Worked perfect and they are very cheap. If your interested I can get you the part number.
Cheers Tim
Cheers Tim
If you have them, please do post, and if you have any picture of placement, I would appreciate that too.
I will check the price for oe parts, but if they are too expensive I will use alternative.
Constant flow has cooling effect, small drops not so much. Atleast I think so. There must be a good reason since porsche felt it was necessary for 968..
True, but the later 2.7L and 3L blocks have windage ports....perhaps that is why? The reason I ask is I have machine windage ports into my 2.5L block. Perhaps I should seriously consider squirters to compensate?
I wish the original knowledge behind those changes would come out of the archives..
