vittesse bridging plug
anyone have one for sale or even a pic of one? Thanks in advance. This is used to bypass a vflex/smt6 system in stg 2 and up kits I believe.
I need one too, so if there is a source for the plug, or schematic to build one, that would be much appreciated! I contacted Vittesse when I first bought my car (SMT6 installed) and it was not available.
You can easily get around not having a bridging plug. You may just need a single wire to bridge 2 pins on the harness (depending on how you wired it).
Jon, thanks, I'm giving your advice a try. I want to run at the optimal specs you defined and not be messing with the results via the SMT6. My situation is I bought the car with your upgrade. Car was running great, but it might be coincidence after I used the PB6 interface to see what it said, car has been running rich. Not sure if I loaded another map, or it is just what happened. I want to get to the base Vitesse setup for my 86 951.
