Porsche clutch help
I'm wanting to sell a clutch kit that is mostly complete. I just need a little help from you guys as to what i have. All parts are like new, I've had them for a while but got them in a parts lot. Here are the part numbers
Flywheel- 951-102-105-1R-P02 (porsche)
Release bearing-3151155301 (SACHS)
Pressure Plate-3082-694-088(SACHS) the last 3 digits are hard to make out and prob. wrong
Clutch disk- 1861568331 (SACHS)
I also have an unrelated clutch fork part # 931-118-8351 (porsche)
If you know what these are i'd appreciate the help. Thanks guys.
Basic Sponsor
Basic Sponsor
944 Turbo PP and Throw out bearing Stock
944 Turbo Fw Stock
944 Turbo Clutch for and pin
clutch disk looks like a 930 disk i will need to see the other side if it's a 930 this is a great package deal
944 turbo bell housing with release bearing guide
944 Turbo Fw Stock
you know your stuff. The bell housing is part number 944 116 401. That is not 944 turbo is it?
Also the clutch fork is not 944 turbo from what i've been reading. The Part number is on the inside. Don't the 944 turbo fork have it on the outside.
And yes i have been able to cross reference the disk to a 930 disk. Will this work on a 944 turbo?
Basic Sponsor
Clutch forks actually the na fork is stronger and properly grind it will work in a 951, where the stamping is located is irrelevant, what matters is the size you will need to measure it.
Basic Sponsor
The 930 disk will work on any 951 it's my choice for modded cars up to 400hp, yes that set up will work on any 951 86-89
here is a thread that will help you find the difference between the 951 vs the na fork
https://rennlist.com/forums/924-931-...l#post10738542
check all the links on the thread
