Installiing a 944 Pan Gasket
#46
If the surfaces were clean, only used a small amount of sealant in the corner (if any) and you torqued it to spec odds are everything is fine. If you are still concerned post some pictures of the bulging areas.
#47
#49
Ok, thanks. Here are the pics after 7 ft lbs and it's moved out a bit more but I think I'm just going to accept it as I don't have the 10 hours of torquing needed for this gasket or the patience.
I just was worried because I've read many threads where bulging was the problem and people started over....
![Name: 04A9FB69-9575-4F80-B1E3-54865324B740_zpsjua62njq.jpg
Size: 217.9 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1199289d1501266183-installiing-a-944-pan-gasket-04a9fb69-9575-4f80-b1e3-54865324b740_zpsjua62njq.jpg)
![Name: 77A3587D-558B-46F4-8047-DE670ADFAFCC_zpswwr7uh3j.jpg
Size: 178.4 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1199290d1501266183-installiing-a-944-pan-gasket-77a3587d-558b-46f4-8047-de670adfafcc_zpswwr7uh3j.jpg)
#50
Letting it set overnight with sealant is the way to go...
Also too late now, but I remember using a wood shim between the flywheel and the oil pan gasket ( better to use a plastic wedge .... so it slides out easier after the oil pan sets up )
Regards
Ed
#51
I thought I mentioned in my earlier post that the gasket did the same thing to me. It wanted to slip out and hit the flywheel ...
Regards
Ed
Regards
Ed
So your's did this and you left it? With no leaking? I still think this is bad but it may just be the flaw in our gaskets and it can't be stopped. My old gasket appears to have done the same thing and then finally stretching a few of the bolt holes around the metal bolt sleeves in the gasket which then looks like it caused the oil leak. Of course it lasted about 10 years first so maybe I'll just be in there in 2026! Ha, I hope it lasts that long! The car I mean, not just the gasket.
Going to button it up now. Thanks for the help everyone.
Crossover pipe, here I come....
#52
Yes, I remember reading your post but I thought you had to redo it to fix that problem?
The did it all over again except I used nothing (dry) and put a spacer in the back near the FW to prevent it from moving initially.
It leaked a little very little and the seemed to abate after a year
If I had to do it all over again I would on questionable use the Yamma bond stuff and then not completely torque anything down until the following day
Good luck
#53
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
This is a miracle sealant, even though it is recommended for oil pan gaskets, I am not sure I would use it on our weird gasket, but others have successfully. I like the Yama or Hondabond like Eddie used, which is really Threebond. Have to make sure which type though, there are several.
#54
I wish I did
I have used Holomar and its very cool stuff I just would rather use the Yama etc if I did it again
#55
...Or you could put studs in place of bolts for your oil pan gasket and then it doesn't move at all. Light coat of oil on both sides like MM123 said at the beginning of this thread and you're good to go.
#56
In the old days Porsche had a big floppy gasket for the oil thermostat housing but eventually updated it to an integrated rigid gasket. Sure would be nice to come up with something similar for the oil pan...
#57
how about a wider gasket? Couple mm. I don't know without a block and pan in front of me right now if it would touch any moving parts on the inside. People have made head gaskets. No reason you couldn't make an oil pan gasket.
#58
I was thinking either something rigid like the oil thermostat housing gasket, or a molded rubber that gripped the block like weather stripping where clearances permit... Head gaskets are flat so a little easier to DIY, but its worth thinking about. For the record, I follow the FSM to the letter, including the most expensive tube of sealant on earth, and have a leak free pan. My was done on a stand with super clean and dry parts, which probably helped, and I also wonder if the weight of the pan helps keep a more uniform pressure around the gasket that way, compared to pressing one little section up at a time when upside down like that.
#59
Good point on the engine orientation.
#60
This is making me nervous, I have no clue now how I am going to do my pan. Dry, wet with oil, or sealant. Who knows, all I know is that I do not want to do the job twice.
Super loaf is your pan leaking?
Thanks for the help.
