Cylinder numbers question
Forgive my question, but my brain just isn't functioning correctly today, and I really need the reassurance. The cylinder numbers are, from the cylinder closest to the fire wall, 1,2,3,4. Right?
Yes, 1 and 4 are paired as are 2 and 3. Depending on aftermarket add ons the injectors may not be sequenital so you may be getting fuel to the cylinder.
The 3 liter blocks have windage ports between 1and 2 and between 3 and 4. this helps keep the air below the piston from having to move through the oil.
Sorry about the baggy being in #3
Because I am clearly mentally impaired, let me be redundant.
#1 is at TDC when #4 is at TDC, so all I need to do is rewrite the lug wires?
Unless I also wired the LR injector harness wrong (backwards) in which case I will need to swap those connections as well. Right?
