Guys can you tell me if this is about right...
Shop quote:
14 hrs for replacing oil pan gasket
10 hours for cam cover gasket
6 hrs for power steering hose x 2 replacement.
appreciate it.
appreciate it.
Oil Pan Gasket can be a bit of a PITA without a 3 piece crossmember. 10 hours is a bit high though.
Cam cover gasket is not even that. I think most would agree 4 hours tops. Do it yourself.
Do the power steering yourself. And it's one belt with another in the way. These are fairly easy to do.
Others should chime in to help.
Yes, I live in a High Rise and frankly don't have the time or probably the skill set in all honesty. I knew from reading the oil pan was a PITA but was shocked by the cam cover.
Those are all high time estimates for someone who knows these cars, but I suppose it depends on the terms. If any of it leaks and they'll make it right on their own time, then those times might not be so bad....
Oil pan; secure the block with a bridge on top of the topmounts. Remove the crossmember, move all bolts, replace gasket, place all bolts back, place crossmember back.. I would say tops of 5 hours..
For the 8valve head; remove fuelrail, remove airfilter, remove front covers for the camshaftbelt, loosen camshaft belt, remove the belt from the camshaftsprocket. remove top coverbolts from the camshaft housing; remove all bolts from camshaft housing and redo al of the above..
I would say all of this can be done in 12 hours tops, if you're a skilled worker you can do it in a day..
I am guessing all of these are book hours. I looked into the oil pan gasket once and was quoted 14 hours. Thankfully, it wasn't actually leaking. I think the book hours on an NA 944 oil pan gasket was less (10 hours?). You're looking at about a $3.5k bill... I would get a few quotes from reputable shops.
Thanks for all the advice.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you plan on keeping the car for a while it might be cheaper to by a 2nd house with a garage out in the country!!
People need to keep in mind that the 'book hours' are based on doing a though job and the clock starts when the car is driven to the lift. I would guess that almost every 944 I see needs an hour of general cleaning before the real work starts. Its bad form to open up an engine if the engine bay is all filled with 25 years of crud....and it its a pan or cam tower gasket job you know its been leaking for a while.
Also keep in mind that this is for 'mechanic speed' work. that includes time to check manuals for procedures, torque specs, ordering parts and such. Race mechanic speed is a lot difference - if time is of the essence I might be able to cut the time in half - but this is based on knowing the procedure by heart, having all the parts and knowing short cuts that don't detract from the quality....and if you want 'race mechanic' work that will be twice the rate of the 'shop mechanic'
This is one one day job for one skilled mechanic with adequate tools and nothing more. If they need more time, they are incompetent.
6 hours for power steering hoses on 944? wtf 15 ton excavator hydraulic hose failure is replaced and ready in less than two hours and 944 steering takes 6? yea right.
I realized Orange County houses aren't exactly cheap either. There are places down there where you can actually rent garage space that has lifts and such. For like $200/month, you'd save yourself some serious coin.
Or, just hire V2Rocket_aka944 to do it for you.
5-6 hours tops for the cam cover gasket, and for that quote, that includes replacing all the seals in the cam tower, not just for the mating surface.
6 hours for the power steering hoses? Are they removing the steering rack to get to them?
Many 944 enthusiasts live in fantasy land when it comes to repair prices. Does anyone take into account how much its costs to run a repair shop? How much insurance costs? Or how about having real techs in the shop? Its very easy to have $8000-$10000 in overhead expenses, think about that the next time you think youre getting ripped off because youre not getting parts at cost...
