Idle adjustment question
I have my doubts about using what 'clarks' describe's as the Idle Adjustment Screw. Yes, it affects Idle, but its more of a Air/Fuel adjustment, - it's an Air Bypass that skips input from the TPS. I have mine glued in at 3/4 off Seat, and set rpm's off the hard stop with the TPS loose and on the Micro Switch. I may be wrong, but I'll risk the flame till the BuilderGroup chime in.
TIA
