non-start problem
non-start problem
have an '87 951, mildly modified with Vitesse MAF, billet fuel rail/Aeromotive AFPR/Marrin damper/SS braided fuel lines and small alternator/Nissan Quest swap
about month ago car started dying, once a day perhaps; then got worse, finally not starting and/or barely running then dying such that I had to have it towed home
replaced alternator with new one; same problem
replaced filter thinking it was a fuel delivery issue; twice it started, ran fine for a while; thinking the problem solved, turned off motor, took it off stands--then wouldn't start
here is what I know: fuel pressure gauge on AFPR showed pressure to what I had set it (3 bar) when the car was running; jumped the fuel pump--it runs, pressure gauge shows proper pressure
gauge does not show pressure when engine not running--gauge is on the the AFPR--to my knowledge, it never has, but then again I never bothered to check it when things were running fine
pulled fuel pump to see if check valve is functional--seems to be, but not sure how to properly test other than to put in new one
system modifications don't have that many miles on them, 25k perhaps; not sure about fuel pump
does DME relay give intermittant operation sometimes? have not been able to swap in a different DME relay to test it, don't have a spare
injectors were cleaned before installation, but haven't tested them at this point
I have zero additional ideas at this point and would appreciate some input
thanks
donn
thanks
donn
you could jumper DME relay socket pin 30 to 87 & 87b for testing.
This will simulate the DME relay BUT be aware the fuel pump will always be running like this, even with ignition off - but it might prove if the DME is the problem or not.
Fuel pump normally only runs when engine is also running, for safety in a crash situation.
When cranking, do you see "slight" tach bounce? Like a 1/16th of an inch? If not then the issue could be your speed / reference sensors.
http://www.clarks-garage.com/shop-manual/ign-02.htm
Have you validated you are getting spark?
Sounds like fuel from your description is okay.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Sounds like the first thing you should have checked but did not mention, DME relay. I assume you have verified not the DME relay? Does the problem get worse when car is warm? In other starts starts fine in the morning at cold start. Then make a drive somewhere park it for a brief time come back and try to start warm and won't fire? If so, DME relay 95%.
non start problem appears solved
thanks for the replies
in my search of this website for ideas, I did not run across this apparent solution to my issue--not to say it is not there, only that I had not run across it
what had been nagging at me was the behavior of the stock volt gauge--it was going absolutely zero
perhaps should have indicated that in my original post
anyway, decided to try one of my spare ignition relays--number G2
viola--volt gauge comes alive as does the engine
at any rate, here's an additional idea in cases of non-starting vehicle where the volt gauge is gone dead
thanks again
donn
thanks again
donn
