Ultra High Flow, Low Cost, 8V Head Project
#211
Note that you have the stock intake port at just under 200 cfm at .5 lift Sean. Remembering that the stock head is meant to have 188cfm max (perhaps anecdotally?). Wonder what that lift that was at and was it at 28" Mercury? Seems to me that the stock head would continue to flow more at a higher lift also. Maybe that 188cfm was at a lower lift or pressure?
#213
Rainman
Maybe you could grind a cam with "rounder" lobes instead of "pointy egg shaped" to make the most of high-end lift...
#215
I wonder if 951 port with 48mm (2.7) valve&seat would make the same bulge on 3.0 mark..
#216
I wonder if they used a thicker seat for heat purposes or just learned more moving forward and improved the design. This makes a significant flow difference especially at lower lifts.
That is the MM head which has now been sold.
Pretty sure that is a no. The velocity is significantly less in the huge 2.7 intake port.
#217
How did you port your head to fit bigger valves you have in the head you are using now? SI 47mm intake valves if I remember correctly?
Something like this, only enlarged where is needed to fit larger valve seat:
#218
I agree that the easy way to get more flow is to use a cam with more lift.
#219
I mean if only lower portion is enlarged, to accommodate larger valve.. I guess velocity would still be retained since the upper portion would be left as is?
Think of it more like a doorway to a building with lots of people trying to shove through. If the people are orderly, more of them might be able to get through a small doorway in a fix amount of time than a large doorway where people are pushing and shoving and bumping into one another. Working on the choreography of the people moving will have a bigger result than just increasing the size of the door.
#220
I understand this, but stock valve and port was designed for 2.5L engine and performs at a certain air port velocity and air mass per displacement in given time/cycle. Lets call it a golden standard.
When increasing displacement, there must be a point where stock port and valve becomes a goose neck, thus bigger valve and bigger port must be used to get proportionally the same (or more) amount of air per unit of displacement.
So, how to achieve golden standard with more displacement?
I was searching the net on the subject and found this, is this true? (right part)
If it is, then if bigger valve is fitted, the rest of port would need to be enlarged to the same proportion in order to retain the same properties (as stock 2.5L) but accommodate more displacement. (more volume @ same velocity)
#221
Yeah, I'd buy that diagram. Makes sense on the cross sectional area. And, your throttle body has to have 4x the cross sectional area into the intake plenum.
On the left side of that diagram, it doesn't show the effect turbulence has... That can help correct some of that rich/lean problem. Have you heard about "wet flow" testing? They use a fuel injector that sprays a liquid that shows up well under a UV light, and they can "see" how the fuel and air swirls into the cylinder at different valve lifts. http://rehermorrison.com/tech-talk-4...de-your-motor/
#222
Interesting stuff, thanks.
