Bob's Build
It took a while but I like the results. The pictures are taken pretty much in order of the build.
Nascar bars on both sides
![](https://rennlist.com/forums/members/rlm328-albums-roll-cage-picture23351-primed-roll-cage-nascar-bars.jpg)
Primed roll cage from the back
![](https://rennlist.com/forums/members/rlm328-albums-roll-cage-picture23350-primed-roll-cage-rear.jpg)
Here is the unfinished dashboard, ultimately finished it in a satin black
![](https://rennlist.com/forums/members/rlm328-albums-unfinished-dash-picture23352-unfinished-dash-passenger-side.jpg)
Roll cage and interior painted
![](https://rennlist.com/forums/members/rlm328-albums-finished-roll-cage-picture23353-finished-roll-cage-pic-from-inside-rear.jpg)
The boby was widened by 3-in (1 1/2-in either side). Fiberglass fenders in front. The rear fenders were cut and modified. Hood is fiberglass with an integrated vent.
![](https://rennlist.com/forums/members/rlm328-albums-body-modifications-picture23354-car-side-prepaint.jpg)
![](https://rennlist.com/forums/members/rlm328-albums-body-modifications-picture23355-car-fender-pre-paint.jpg)
Cold air intake, intake is through the old fog light. Gets a little "ram" air action at speed.
![](https://rennlist.com/forums/members/rlm328-albums-cold-air-intake-before-new-header-picture23356-cold-air-intake.jpg)
Engine ****
Knifed crank at home in the block
![](https://rennlist.com/forums/members/rlm328-albums-engine-****-picture23357-crank-in-engine-bottom.jpg)
Coated pistons, ceramic on top teflon on the sides
![](https://rennlist.com/forums/members/rlm328-albums-engine-****-picture23358-piston-after-coating.jpg)
3 liter block ready for the head
![](https://rennlist.com/forums/members/rlm328-albums-engine-****-picture23359-engine-pistons.jpg)
Header side of the engine
![](https://rennlist.com/forums/members/rlm328-albums-more-engine-****-picture23361-engine-on-stand-header-side.jpg)
Testing the clock on the turbo. The clocking bolts were a tight fit.
![](https://rennlist.com/forums/members/rlm328-albums-more-engine-****-picture23360-engine-on-stand-front.jpg)
Final product without the splitter
![](https://rennlist.com/forums/members/rlm328-albums-car-with-wing-no-splitter-in-shop-picture23362-car-with-wing-shop-side.jpg)
Engine ****
![](https://rennlist.com/forums/members/rlm328-albums-car-with-wing-no-splitter-in-shop-picture23363-car-with-wing-shop-front.jpg)
Nice going Bob! What size is the motor? You're running Motec too, specs? Did you re-wire much of the car?
Nice dash too. Bit of work there. Power to weight figures yet?
The wiring in the car has been almost totally replaced, we pretty much built a custom wiring harness for the Motec. I am running an older M4 which I plan on upgrading in the spring. While there is nothing wrong with the unit I am having problems finding a computer that will talk to it. The new M84s are fairly reasonable now that Motec is getting some competition and almost any computer can operate them.
2600lbs is light if it's all still metal. I'm at about 2550lbs with fuel and that's with hardly any metal left so you've done well if that's where you're at! Sounds understressed and good for longevity. Be good to get some videos when you can.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yes, a big bowl is needed to keep the 8:1 - but the quench area on a 951 is an important part of the old school design - it creates a lot of turbulence in the combustion chamber as the air/fuel mixture is pushed towards the center of the cylinder as the piston approaches TDC.
