AFM output voltage - strange behaviour
#46
Do you have a wideband O2 setup? what are the readings on cold start? An adjustment to your amf may solve this issue as it sounds like a cold fueling issue to me.
#47
What kinds of adjustments can you do to the afm?
I was thinking that if the TPS was worn at the start of the trace and produced a bad or noisy signal then it might account for the poor behavior. Just a thought.
#48
Tried measuring fuel pressure today. I'm not really sure what I found out though because I just realized the gauge doesn't make sense to me. This might be a stupid question, but why the hell is the 0-5 bar scale smaller than the others? How are you supposed to read that? This is the Arnnworx gauge, but I have a HF one lying around, same story with the gauge on that.
Here is what I had with the engine off, fuel pump jumped:
![](http://i1189.photobucket.com/albums/z424/an_broc_si/20131102_140050.jpg)
With the engine idling, the needle was jumping quite a lot - sometimes it would settle down, sometimes it got quite erratic, by as much as 1/2 a bar. When I revved the engine a little it would smooth out:
![](http://i1189.photobucket.com/albums/z424/an_broc_si/20131102_140954.jpg)
Here is a video of it at idle - this was not the most erratic behavior I saw, it got much worse but I didn't catch it on video (sorry if this video appears upside down, that should be fixed as soon as youtube is finished processing):
Does that seem right? I just remembered that is it actually a 3 bar regulator. It was on a spare fuel rail a friend gave me after mine got damaged. I left it on there to avoid the risk of damaging the rail...but the car has always run the same as it did with my old 2.5 bar.
#52
I had a similar stumbling / irregular running on my 951.
dont know if this helps, its a long shot, but I actually had a jubilee clip (the big J Boot one) go wrong. It failed in a strange manner, i.e. - at almost the point it was torqued up it jammed on the thread, and I thought the J Boot was tight. It was not and the leak which followed made the car run just like yours.
I was over familiar with the various intake pipe connections as I have been DIY maintaining one of these cars for 10+ years.
At tick-over, there is no boost pressure as you will be aware. If you fitted a boost guage it would read negative pressure. Therefore the arnnworx pressure test is irrelevant at tick over. Failing that, HT leads are a favourite, tick over, enrichment on the afm, good luck, you will sort it.
#55
Put the original FPR back in - no difference. Well, there is a big difference on the pressure tester - the needle no longer bounces around erractically, it's now very stable, but the car idles and drives exactly the same as ever.
Funny you should say that - last week, as I mentioned, I resealed the throttle body. It was leaking, and the reseal kit fixed the leak, but had no effect on how the car ran. A week later, I disovered that I had completely forgotten to tightnen up the AFM/J-boot hose clamp when I put the TB back on. It was loose, and I mean about an inch too big. The J-boot would undoubtedly have poppd off the AFM if there was enough room in the engine bay. I tightened it up, and of course, it made no difference. Weird though...the car ran for a week, the same as ever.
Still, if the behavior you saw was the same as mine, it does point back towards a vacuum leak. I need to make a new test cap and test again.
Not sure what pressure test that is...I was trying to pressurize the system from the J-boot in my test.
#56
I think I have begun to isolate at least 2 different issues here. I tried adding 6% more fuel via the FQS switch, and drove the car for a few days. It definitley seems to have improved the idle and general running of the car. Previously the car would always shudder when idling as if a train was driving past...with the extra fuel that problem went away. Acceleration was also smoother, and my exhaust did a lot less popping than usual.
However, it didn't have the slightest effect on the weird stumbling issues on cold startup.
I did check the TPS again very crefully...opening the cam as slowly as I possibly can I cannot get anything from the idle switch except 0 ohms or infinity. When I release it I do see a very brief flicker of some value but it's too fast to read. I don't think that's the issue.
I did find a few small vacuum leaks around the 2 small banjo fittings on the intake manifold. There are a few small vacuum lines and fittings there I never replaced so I'll get to that next.
