Coil - harness connection ?
Dumb question here, but here goes...
I changed the wire end connections on the harness coil wires. There's a black and green wire. I'm fairly sure, but would like confirmation that the black wire goes to the positive on the coil?? yes?
Yes, black wire goes to + on the coil. This always throws me off as black is generally ground. Green wire goes to the DME as DME controls the ground to the coil.
Agreed - black is positive. Makes me want to re-start one of the "most inexplicable things" threads -- like the (trapped) M12 bolts used to hold a 2 ounce heat shield over the starter.
