Rogue Tuning - New Product: A new DME!
I just thought that you guys joined the same venture. I know you have the capability, and Tom also seems to be a bright guy. When you guys started talking about it I had some thoughts too, but more for the knowledge that I would acquire from you guys.
Small Business Partner
I'm sure this new DME is a big surprise - I've kept very quiet about it for a long time. As such, it has been very hard to get an idea of the market. Should I build 5 or 50 or 500? This greatly affects my cost/time/investment.
As soon as I have a bit more clear idea of the market, then I will post pricing (at least range-it).
Joshua
Very impressive work, but I have to ask - Who are you marketing this at? Perhaps you could elaborate on some of the features that would make this attractive to purchasers? If it is just the same as stock, why wouldn't you just buy a used DME (unless this will be cheaper)?
Do you still need the knock computer as well?
Joshua
With the new DME, it carries a limited lifetime warranty - it is built using the best PCB boards & components, designed to be very robust and reliable. This computer should outlive the 944 series.
Yes, the 951 still needs the KLR. It does assist in diagnosing a KLR issue; with the new DME, as you can flip an internal switch, which will bypass the KLR.
Additionally, the new DME does have a small expansion plug on the back. This is for anyone wiring in a WBO2, and/or MAP sensor - you will not have to cut the factory wiring harness.
Furthermore, if I wasn't clear, this DME will work in the 944 or 951, with only flipping a switch & swapping chips.
Moreover, this DME will properly run aftermarket ignition coils (with proper dwell) without any other mods. Similar is true with the injection driver being able to run low-Z injectors without resistors, or my high-Z units.
The much newer designed practices should also have other 2nd order effects, such as more consistent reading of the sensors due to better ground plane & power supply, board layout, ect.
Wow. Very impressive!
Freedom Enthusiast
I don't see the switch that converts it into a full MAF kit for an S2 turbo.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
That said, I am working on changing the factory software to be more reasonable - and am getting very close to being done with the 944S MAF. The S2 will be next and shouldn't take much work after the S is done, since they share many similarities.
This new DME will not work in a 16v car. You people already have a robust computer
I need one of these!
Allot of cars have ECU problems and the owners dont know it.
I have changed 2 units as the first one did not work with the o2 sensor so i had to plot the idle and cruise with the piggyback..
The second DME made ground issues for other stuff and the car would not always start...
I dont know what i have now or if it work right all the time...
Though I would obviously like people to run my stuff, I did not intentionally remove any compatibility with the original DME. Any chip that will run in the stock DME will also run in my new ECU.
The resistor which would be cut in the original DME has already been removed on my new ECU (as it served no factory purpose). There is no hardware modifications needed to run the current MAP sensor addition setups.
