Are there any pros to the 951 engine?
Many other engines are famous for certain things that makes them special. It seems like the 951 engine has nothing really noteworthy about it aside from "well its kind of big for a 4 cylinder.."
An opendeck block with notorious rod bearing problems and a turbo on the wrong side, didn't even come in 16 valve form. What does it have going for it?
Depends on what you compare it to I guess.
Such as, if you compare it to a 944 NA engine....
So, what is the deeper meaning of asking this question? Are you contemplating swapping in another motor from a different vehicle? If there is an obvious benefit in doing so, then go for it.
The pros are that its a factory block which has its basis in a design that stems from the 70's. It is an 8 valve SOHC 4 cylinder with many, many less than ideal attributes. With a few simple mods it had the potential to (fairly) reliably make some pretty decent power. It still manages to embarrass modern sports cars...Go find another 70's or 80's 4 banger that can claim that.
Torque. Plus as Doug says, compare it to other motors of it's era. Not that you don't raise decent points. Would have been great if they'd managed to develop it further...alas...
For its age it is very advanced. Sodium valves, ceramic exhaust ports, al. Cylinder wall (not sure this a plus), advanced exhaust manifold materials, lots of torque, and fairly smooth for its size and age of design.
For Porsche, I'd say it is nice because it is EFI over the CIS system that was still in use on the 911 turbos. Also, it was full world engine which means the power was the same in the USA as Europe which is HUGE for the era. Most performance Euro cars (M5, 535i/any that used big-6, 190e-16v, 928, and etc) of the 1980s came to the US down 20 or 30 hp. It was only until the mid-90s for instance that BMW started producing worldwide engines. And, more recent M3 i6 engines still differ by market.
The 951 turbo set up is truly remarkable. From the factory it came with all of the goodies (FMIC, turbo timer, external wastegate, oil cooler, headers) that are "upgrades" to most production turbo cars. I am still amazed at how short the intake piping is on the car (coming from DSMs where piping went long to fit FMIC).
The 951 engine set up is more a sum of its parts oppose to any one specific design attribute.
Hydraulic engine mounts were derived from washing machine, and later copied by other car manufacturers.
Pros? Forged crank, rods and pistons in a relatively cheap package. (Except the 89+ cars with cast rods but no one wants an 89+ anyway ). Overall its immensely strong given the factory HP output.
My early interest was in Japanese cars (SR20's, RB's). Although they could make reasonable power with mild upgrades there was no doubting the effects the cast internals had on longevity.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
that moment he realizes (2.5 liters) in full tune only hints at the potential of the car – and the only family swap that effectively deals with the lack of mid-level power is not only extremely expensive to build, but just another maintenance hog to daily drive for many years *(but, bulletproof).
of course, far-worse would be doing a 3.0/968 Turbo S replica.
we'd be fully terrified a bird might crap on it.
The pros would not include that has its basis in a design that stems from the 70's:
As it is an 8 valve SOHC 4 cylinder with many, many less than ideal attributes. With a few simple mods it had the potential to (fairly) reliably make some pretty decent power. It still manages to embarrass modern sports cars...Go find another 70's or 80's 4 banger that can claim that.
The 968 turbo not only beautiful but very powerful. A slippery slope that can haunt someone for many years. When mated with the N/A2.7 head can be very reliable, and cost effective using majority 951 parts. I have not had any maintenance issues in years.
True, but both those cars were designed and built with competition in mind.
