-044 Fule Pump Line
I am getting ready to install an -044 fuel pump. I didnt get fittings with it.
Does anyone know if the fittings typically used are an -6An or an -8AN fitting?
This is the -6AN
http://www.summitracing.com/parts/ea...6erl/overview/
Or is the -8An used?
http://www.summitracing.com/parts/ea...8erl/overview/
I cannot find specs on what size hose is used with each.
Anyone know which of these to order (and yes, I need a metric adapter too).
This is the -6AN
Thanks.
I already did a search and also found those.
The second thread talks about thread pitch (I just need a 12x1.5 metric adapter).
In the first one there is one post that says
"-6 AN fittings and braided hose"
Another post in the thread:
"I used 8an braided line for the inlet"
This is why i am trying to figure out what adapter is generally being used.
-6AN or -8AN
I suspect the -8An has more fuel flow, but, does the fuel line fit over a -8AN?
-6AN or -8AN
I used -8AN for the inlet since this size hose fits the outlet nipple coming out of the fuel tank. I used pushloc fuel hose and standard hose clamps. The fitting is -8AN 130* bend, pushloc. Might be 120* bend, can't remember exactly.
Pump outlet is -6AN pushloc with a 90* bend. Again, I used -6 pushloc fuel line since it matches the diameter of the stock rubber fuel line.
