help! engine knock at idle
Also, if you have the factory toolkit, there is a 6mm allen key that will reach the bolts inside the cam tower. You can just hook a box end wrench onto the short end for leverage. You will still need something you can attach to a torque wrench to for putting it back together though.
You shouldn't have to pull the intake either though right? In fact do you really have to remove the timing belt, or just de-tension it and slip it off the cam sprocket? That should save you having to touch the balance shaft. Then just check the routing around all pulleys carefully when you're putting it back on and re-tensioning.
all right thanks guys, been messing around with my ac compressor right now, cant put it back in place lol, wanted to look if my timing isnt off, because cam sproket when i got to it was kinda lose, i think it ruined the seal there while it was lose, i wonder who was messing with it before me and didnt bolt it on properly
Loose? The sprocket itself was loose? Wonder if you have a broken bolt holding it to the cam and/or if that is related to your clattering? Usually those things feel tight even after you remove the bolt. Definitely worth getting to the bottom of that....
You will need a triple square socket for that cam bolt. You can sometimes find them at Autozone.
i have a specialty tool kit for vw/audi/porsche with special sockets
yeah when i took distibutor cap, thats what got my attention the whole thing was moving around
Also, if the sprocket was moving around, the rotor and cap would have really unusual wear. If you can post the video, pan over to the rotor and the inside of the cap for us.
sorry for vertical video, i only have two hands, and it looked good on the phone :d
so when i removed timing belt cover there was oil all over the place.. and i lost one of the intake manifold vacuum bolt somethere in engine bay, its like a black hole nothing ever falls out on the ground
I think you are lucky you caught this when you did. You really need to pull that sprocket now, and see what the woodruf key looks like. As Tom pointed out the sprocket should not be loose like that even with the bolt backed out. The key could be damaged. Presumably this was the source of the noise all along?
As Divil stated, your woodruff key is most likely pretty mangled. I would take this time to replace it with an offset key and advance your cam 4* to pick up some low end and midrange torque and quicker turbo response. Its a cheap, easy dyno proven mod.
minor setback.. broken tools, ill post pics tommorow. i was able to remove sproket and woodruff key, didnt take a good look at it but it looks ok, anyway, ill give uptades tommorow going to sleep.
