Bad bearing on water pump
My failed WPs always seem to leak that green fluid and the radiator pressure test often shows a pressure drop/leak. Do you have any similar signs? I'd open it up and find the cause - WP, idler pulley or whatever. Once it's making noise, it needs to be fixed whatever it is, and it's the same place for all, unless it's in the alternator, AC compressor or PS pump. If you've ruled out those three accessories it's time to open it up.
OK, last night I got the intake system, the lower pans, and the outer belts off. I noticed a small coolant leak from what looks like a temperature sensor below the upper coolant hose to the radiator. I've attached a video for verification. It looks like a leak from a brass fitting of some sort.
The video quality isn't great in these conditions, but basically Im by the front left wheel under the car looking up at the senor. Above the sensor is the radiator hose.
What is this brass fitting (engine temp sensor/fan sensor?) and can it be changed with the radiator in the car?
