low vacuum, hard hot start problem
'88 944 turbo with mtune.
I have a low vacuum issue. When warm, I get 10-15 in vacuum at idle. It seems that when cruising, I let off the gas and the vacuum will go to -20 for a split second then to about 15 but if I feather the gas just slightly, it will go back down to -20. Its real weird. also, at times the idle will stumble going back to idle. It takes a couple seconds to even out.
As far as the hot start problem, It will start up fine but have a hunting/ surging idle at ~600rpm for several seconds then even out.
The tps, isv, and o2 sensors are all new. reference sensors are older but are properly spaced.
-maybe the dme temp sensor as that is old.
-vacuum lines are new
just weird issues
Any and all help is appreciated.
just weird issues
Small Business Partner
Definitely check the DME temp sensor...
Also, if you haven't, then reset the idle:
http://www.clarks-garage.com/shop-manual/fuel-08.htm
Additionally, you can try adjusting the fuel a little by changing the FQS. Try going from position 0 to 1.
OK, I will reset idle again. And as far as the temp sensor, can I test at sensor or do I have to do it at DME? Also, I remember you saying the timing will change vacuum but would it do what mines doing where I get more vacuum as soon as the tps clicks
Dillon, have you tried adjusting the FQS?
Idle issues are usually related to the TPS, and/or wiring...
Also, do you have any logs that I could take a look at?
Quick and easy fix for me was to resolder the joints on dme relay.
Had those ghost-ring looking cracks on solder joints and this was a newer dme relay. So maybe heat/current would expand the bad joints and cause a bad connection only when warm.
