Standalone's ?
#31
I am just trying to get the damn thing to run right. The mafterburner is an absolute joke. The car runs differently evertime i drive it. I want it to be more drivable and make more power. It's to rich right now and has no bottom end, wont even light the tires up when it should. My mechanic says he can tune a car with a motec with his eyes shut sitting on a beach in the caribbean.
The hard part is not the duty under 70% or greater load, it is about the drivability in the 25% to 30% load range that is the killer. That is where all the tough mapping takes place and where you will do the majority of your driving. The dyno will place it under about an 80% load and as such will get decent mapping from it. But that region is the easy portion as it takes no finesse as the injectors are basically hoses putting the fuel to the cylinders as fast as they can.
Where is he talking about taking the ref and sync from, crank, cam or a combination? Who is buiding the harness? Who is pulling the old harness? Be careful of what wires you cut as you may not want to lose that portion of your functionality.
#32
For example, when I put an aftermarket ECU on my NSX I flew up a guy from California to check the system over and then tune the car. Why? Because this guy does up to 10 of these installs a month on NSX's with this exact system and he had me up and running in an afternoon with a tune that works. He also spotted a few things that needed to be changed in the install that someone who wasn't familiar with the cars or the ECU may have missed. Having him up here was priceless for me and saved a ton of guess work that someone else would have done.
Summary - use the system your shop has experience with. If you want to use another system find a shop that has experience with them. The shop is the biggest part of the end result - not the particular ECU. Again just my $0.02
