Dyno'd the car....results inside
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Ok sounds good to me. I see your not that far away you ever get to VIR with you 951?
Brian,
not sure if you remember me, we met a few years ago right after I bought my 944 turbo and it bent valves two days later... I got the car built up with a new head and am planning a turbo swap this summer. I'd be very interested in the dyno day if you have another one.
Greg
Greg
Brian,
Greg
Greg
Brian
Odb812 - I noticed the same thing, but it spools much sooner on the street. 36-3700 I see full boost. No idea why it took so long to spool on the dyno. I've gone over everything, and it's all buttoned down tight.
They did the pulls in 4th gear, right? I still think 36-3700 is a little bit late to hit 18 psi with that turbo.
Greg
Yes, pulls were made in 4th. 36-3700 seems to be the norm from what I've seen for the Kokeln V. Keep in mind I'm on the stock DP, 2.5" exhaust, and I have a cat.....so that most certainly is producing some back pressure.
