Hypothetical - new engine from Porsche or rebuild?
#31
Don't know. Well there wasn't something loose found in there so you have to make supposition based on the clues. Looks like maybe some localised heat at the rear of the block.
#32
The unfortunate thing is shipping an engine from overseas is horrendously expensive (you would be really lucky to finda 968 engine here). Figure about $1,000 with most of the cost in the port handling charges at this end (the sea freight part is only a few hundred). Obviously air freight is more again.
#36
Piston squirters are simple enough to machine into your S2 block. I do have a spare 968 block, but it would need remachining as it has a scratched up number 4 cylinder.
