FS: T04E Stage III with Turbonetics Replica #8 and Garrett GT3076R Parts
I have a T04E for sale, this turbo did great on my car but now I moved on to a larger 57trim. Found out my car smoking condition is related to valve seals not turbo related. I also used a restrictor which will come with it. The turbo is in great condition no chipped blades and spins excellent with very minimal shaft play. Less then 5k miles on this turbo and was purchased this past fall/winter.
With this turbo on 18psi and depending on supporting mods I believe would be around 310-330whp.
Hotside: Turbonetics 8# Replica <--- Sale Pending on Hotside
Coldside: BAE Polished .50 AR
Center: BAE CHRA
Compressor Wheel: 50.8 x 76.2mm
Turbine: 65.5 x 56mm Stage III Wheel
I'm also including my Garrett Wheel and Housing... Machine the wheel to 1/4in and it all will bolt up for a GT3076R turbo.
The Turbonetics housing alone goes for close to $200 and the Garrett Wheel and housing is at least another $200-250 by themselves.
I need this gone.
Price $200 shipped except Hotside Housing
Center: BAE CHRA
I need this gone.
Not bad at all, I personally never see 4th except on interstate so I usually see low gears and this one was good combination of response and power. I would say spool is similar to a K27/6.
