Kyle I spun a rod bearing, so i'll be needing stuff soon. You have any new'ish water pumps? Also, where we at on the STD rod bearings? You still have them?
So those pistons will work on stock cylinders without modification? What rings do you need for them?
These pistons will fit in the stock bore. You may have to get the pistons coated. Maybe someone on the forum can give us a better answer to that. I was using stock piston rings
