rear suspension thoughts for my 951
I don't really see how there would be a requirement to change to different bushings. The weight of the car is on the spring plate regardless of wether or not a TB is installed. Hence why most of the time when you pull them, the bushing is deformed.
I've used polygraphite and delrin bushings. I really didn't care for the poly and those are long gone. Fitment was too loose so more slop than the original rubber. But the fitment is likely a brand/mfr issue, so others may or may not have had that problem. Delrin is ok. If I had it to do over, I would have used the ER poly-bronze. These were all dedicated track car applications. Not sure its necessary to dump the rubber w/ t-bar delete on a street car.
Lots of threads on this topic and you will find a huge range of recommended spring rates, different numbers used for motion ratios and effective rates, different theory on suspension design and setups, etc. often leading to some heated posts. As with a few other 944 hot topics, you won't find a general consensus on "best" spring rate. Too many variables.
It seems that a lot of confusion comes up as to the exact math to use for the rear. From what I have found, the correct ratio is .42 to determine the rear effective rate. Lots of people seem to think that .65 is correct but for the actual ratio, you must square .65 which then equals .42. Paragon even has the incorrect .65 on their site. And the difference in using these numbers results in quite a difference in spring rate.
So does anyone not agree that .42 is the correct ratio?
Front ratio tends to be around .92-.94 so that is close enough for our use.
And then there are quite a few variations in front to rear ratio which can be affected but tire stagger and other variables but basically a similar effective rate front to rear seems to be the consensus.
And finally, these cars handle pretty damn well with stiffer rates, so much so that I think a decent driver can put up with a less than perfect balance, more so on the street and up to point of course.
Correct.
