rear suspension thoughts for my 951
Old 05-13-2013, 02:42 AM
jss
jss's Avatar
Default rear suspension thoughts for my 951
I currently have konis coil-overs in front with 275 spring rates.
which I am happy with for street use.
I also have LR 30mm front sway and LR 5 way adjustable 19mm rear sway
now the torson bars are upgraded to 28mm/koni shocks I really want to ditch all that and just get a set of coil-overs so I can adjust the car without the bars in etc.
first question is whats a nice match to the front 275 spring rates?
best place to shop for them?
lastly I understand all I need to buy after words is bushings correct?
Old 05-13-2013, 04:22 AM
fred27
fred27's Avatar
600 lb rear springs
Paragon Products
Old 05-13-2013, 11:27 AM
jss
jss's Avatar
600 to match 275 fronts sounds really high?
I was doing research today i thought around 400
Old 05-13-2013, 11:38 AM
Scott H
Scott H's Avatar
To find the wheel rates using coil overs you use 92% in the front and 42% in the rear.
.92 x 275 = 253
.42 x 600 = 252
Old 05-13-2013, 12:06 PM
jss
jss's Avatar
interesting thanks alot so I need to shop for 600 to be good balance with my 275. got it now
Old 05-13-2013, 12:17 PM
jss
jss's Avatar
Default Rear coilovers more or less the same thing? paragon vs the ground control kit
thanks again
Old 05-14-2013, 08:42 PM
Oddjob
Oddjob's Avatar
600 is a lot of rear spring for a 275 rate front, unless you are setting the car up for auto-x and want a lot of rotation...
Somewhere in the 400 to 500 range is going to be a more neutral match for the given front rate.
Old 05-14-2013, 09:14 PM
jss
jss's Avatar
this will be for street use which is why i went 275 fronts and not crazy I just wanted to see my best match for rears
Old 05-14-2013, 09:41 PM
Zeff
Zeff's Avatar
How did you like your 275 28tbar setup?
Old 05-14-2013, 09:58 PM
Darwantae951
Darwantae951's Avatar
I run 300/500
Old 05-14-2013, 10:15 PM
C ANDERSON
C ANDERSON's Avatar
550/700 on Ground Control Koni's
Old 05-14-2013, 10:24 PM
Lightningmcnulty
Lightningmcnulty's Avatar
I just ordered a full set of koni coilovers from Jason at paragon and he told me that 300lb fronts go with 450lb rears for a balanced street setup.
call him and discuss your needs
kim
Old 05-15-2013, 11:08 AM
jss
jss's Avatar
that sounds about right its funny how there is so many versions guys are posting what to get.
I was thinking 450 to 500
what bushings you all using when deleted the torson bars?
Old 05-15-2013, 11:13 AM
Darwantae951
I kept everything in the rear stock except for poly-bronze spring plate bushings.
Old 05-15-2013, 11:35 AM
jss
jss's Avatar
guess your talking about
Bushing - PolyBronze Spring Plate Bearing Set - Elephant Racing?
Quick Reply: rear suspension thoughts for my 951
