pic of under side of car request
#31
at least it's on its side...
not my car, hope it helps.
To funny, I just realized the OP is years old. Sorry no front end photos.
#33
Here's a line drawing out of the work shop manuals.
Also, I have the front splitter and both engine trays off my car and hanging on peg board in the garage. I'll take photos of those tomorrow with a yard stick in the photo for scale.
#34
Thanks in advance.
I'd like to collect some underbody pictures for the guy who will do the body work.
And I have already found very good ones here from the back side.
First time I have checked the under body at the bottom of the front wings I've thought it is very much rusted as there is a hole there and only a small clamp fixing it to the sills. But later on I've seen a pic of a used front wing and it looked similar to mine. So I hope there won't be too much to do.
And even the Haynes manual has just arrived yesterday.
#35
The Haynes manual is nice to have but if you plan to do a lot of work on the car look for a used set of Porsche manuals or even pick up a CD Rom with the files. Well worth it.
Pics below. After copying these to my pc I noticed the focus isn't great. I could re-shoot them if you need better images.
#36
Thansk again, but it seem like I can not write down correctly what I'd need. (I'm from Hungary and so I'm not a native english speaker...)
I need some pictures from the underbody, from the front wheel arch. How the front wing (fender?) is attached (bolted) to the rest of the body.
#37
As taking off the plastiques from the 2 sides on the front most of the screws have broken.
How to replace them? Are they welded into the sills?
Is there a replacement element of the front left/right jacking point?
#41
Where the bottom of the front fender(front wing) is joining the sills. Where the front jacking points are.
Especially the passenger side is rusted, but the driver side is also deformed a bit. And I can not see how the bottom of the fender should be fastened to the under body. Best would be without the 2 plastic trays bolted on.
#42
Sorry, but I won't be taking the trays off till something is requiring me to do so. I'll see what I have. Still want pictures with the trays on? Only the front tray is plastic.
G
G
#43
Mark up a picture of one with trays and I will look to see if I have one ?
I am sure I do
regards
Ed
Dwizle (09-18-2021)
#44
Nice - but things only look that pretty till you drive it. Every time I have one of my cars on a lift - I get some goggles on and clean things up while wearing raingear.
