New swaged fuel line fittings
I got the cheaper hose kit from rennbay 2 years ago when I first got my Mtune when that short hose on the rail started leaking after doing the injectors. Those metal ends on the old lines were a pain, but I haven't had any issues since.
Just a quick update- New fuel lines are on, they are gates barricade which is rated at 260+ degrees, 225 psi working pressure, and is E85 compatible. All connections are double clamped at both ends with SS fuel injection clamps rated up to 250 psi. I used 3/8 line for the high pressure side, and 5/16 for the return. I reused the factory JIC barb fittings after carefully cutting away the factory swagging. I have deleted the fuel damper as well.
