3.1l 16v turbo 91 mm stroker dry sump build
#76
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Duke, did you try increasing peak values in the RPM limit table?
I could be wrong but I got the feeling from playing with the G4 software on another car that the algorithm for the RPM limit kicks in earlier in the RPM range the faster the engine spins and/or the higher the load, which should be the case under peak boost.
#77
How do you know he's already got only one left... ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I havent scoped the trigger signal under load but it's perfect without load to 7500 rpm. Just had the crank sensor mount reworked to take a newer type crank sensor which gives a cleaner signal. Next test is in 7 days.
So far I've had issues with injectors, fuel pressure regulator, variocam unit etc and all of them intermittent and giving weird results. Was driving me crazy for a while!
#78
You know me too well! I've burned more ethanol than the car the last month or so ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I've had all kinds of weird issues and none of them is related to the bottom end. So the stroker is working perfect! 2 things still on the table to fix. The weird "soft rpm limiter" above 6000 rpm while on boost and I noticed on the last shakedown that I need to gear down the oil pump to get higher oil pressure.
Will write some more later on.
#79
Thanks Shawn!
1. We have not designed the pistons with this in mind. Similar valve pockets as stock.
2. I don't have this spec written down. The shop assembled the crank and did some measurements after the crank was done and concluded it was fine. It was then balanced as the final touch.
3. No. I had the bearings coated in my last 3.0l 16v turbo and that damn 2nd rod bearing went south anyway
These bearings should be much better than the stock ones and being a race engine it won't see many miles in 1 season. Will most likely replace the bearings every season just to be sure.
4. No deckplate. The siameseed block, the large head studs and the pinned girdle should be plenty stable. Had no issues at 514 rwhp with this setup in the past. (But a deckplate wouldn't hurt though!)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
