Bleed Your Clutch the Easy Way!
It was not that many years ago that I had to replace my clutch slave cylinder on my first 944. After two nights, brake fluid everywhere, and maybe a few choice words under my breath I successfully got it bleed.
Over the years I got better at it with knowledge and techniques like jacking up the back of the car, keeping the reservoir completely full, etc but it was still basically a miserable job.
A while back I considered buying a power bleeder and then came up with an alternative that I have now used several times successfully. I already had a coolant pressure tester that I bought from Autozone for $75. I hacked up one of the adapters I never used and attached a bit of hose and with this setup I can bleed the clutch in 5 minutes! With the hose on, I fill the reservoir completely full and even a bit up into the hose. Then apply about 5 psi and after 1 or 2 tries the job is done.
Nice ingenuity.
While reading through the shop manuals recently there is a little nugget of info on how to get air out of the lines that I have rarely seen suggested. I've used the pressure method a few times with varying effect, usually deferring to pushing new fluid in from the bottom. I plan on using the book method next time I bleed to see how successful it is (lines are bone dry, so it should be a nice test); it's reminiscent to how I bled my E36 clutch slave, only I had a tool for that which would hold the slave and compress the piston (seen here )
Nice ingenuity.
While reading through the shop manuals recently there is a little nugget of info on how to get air out of the lines that I have rarely seen suggested. I've used the pressure method a few times with varying effect, usually deferring to pushing new fluid in from the bottom. I plan on using the book method next time I bleed to see how successful it is (lines are bone dry, so it should be a nice test); it's reminiscent to how I bled my E36 clutch slave, only I had a tool for that which would hold the slave and compress the piston (seen here )]
Nice. Cheaper than a Motive Power Bleeder too (which is what I use...)
http://motiveproducts.3dcartstores.c...der_p_115.html
I've been using one for the last 8 years, only have had to replace the hose. Make sure you clean the hose out before you put the bottle away for a while, because the next time you go to use it, the hose will blow out spraying brake fluid everywhere. Luckily it was my beater E36 at the time so I didn't really care about the paint damage, but it's something to watch.
It sorta kinda defeats the purpose but I don't actually put fluid in it. I just use the bottle for pressurization. When the fluid gets low in the reservoir I pull it off and add fluid.
Stories of the hose rupturing and blowing fluid everywhere like Scott said scare me.
Swanky, well done Shawn!
Did you 'buy' your bleeder like I did? I borrowed it from Autozone, decided it was a great tool and ended up just keeping it and letting them charge me for it per the agreement.
